I'm using Dvd shrink 3.2 and dvd decrypter 3.5.4.0. Half of the dvds i burn, skip, start and stop or just play badly. Half work great. 4 different players usually the same result. Any suggestions to what I'm doing wrong. Thanks, I'm new at this.
Hi clavin29,
Welcome to the forums.
What disks are you burning to? What you describe is often poor or damaged media (disks).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Try RIPPING the problem DVD discs back to your computer ... then play them from the HDD using PowerDVD or WinDVD and see how that goes.
If it plays OK then you just need to burn again with a good burning program (ImgBurn 2.x) and good DVD media (Verbatim 16x DVD-R or Taiyo Yuden 8x or 16x DVD-R).
It may be that simple.
Then again it may not be LOL
You can also try burning at a slower speed. Imation disc arent exactly the best disc and Ive found that out the hard way. Thats when I tried burning at a slower speed the disc worked fine. Not all, but most. Use them but dont get them again. Now I either buy TDK or Verbatim.
Better yet buy them online . Get 200 count for about 44 dollars @ shop4tech. Best of luck.
Happy Holidays to all @ this wonderful site of Knowledge.
Life is like a pothole, you just have to learn to get around it. -
You didn't tell us what brand of drive you are using.
Some brands of drives are more media sensitive than others.
Your drive should also have up to date firmware. If your drive does not have the proper media strategy for the Imation disks, the results will be poor.
Gadget to start/stop recording two camcorders at same time?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Feb 2012, 17:41 -
Playing Videos in a certain order with only certain start and stop times?
By spudz72 in forum Software PlayingReplies: 0Last Post: 5th Aug 2010, 01:56 -
Videoplayer with start/stop and overlay drawing function
By videoamateure in forum EditingReplies: 6Last Post: 14th May 2009, 19:21 -
Trouble Synchronizing English .srt and Chinese .ssa Start/Stop Timings
By DonutFiend99 in forum SubtitleReplies: 4Last Post: 11th May 2008, 08:11 -
DVD-R recordings stop and start during playback
By Walsallian in forum DVD & Blu-ray RecordersReplies: 24Last Post: 11th May 2007, 07:14
