I noticed a slight improvement using an AR s-video cable ($12 eBay) over the stock. Same thing with a new IEEE over my stock cable.
The point is, a small improvement here, a small improvement there...it all adds up.
Results 31 to 34 of 34
Buddy if IEEE is digital how can you see image improve...??? if the data is copied bit per bit... anyone?Originally Posted by zoobie
The only Monster S Video cable I bought failed after a few months(the human hair sized wire attached to the plug kept breaking). I saw no performance gain from the gold plating or anything else about it.
I wind up using average cables, usually the ones that come with one device or another until they wear out from use, then buy a mid-priced cable, not the cheapest, but $30 for a "Monster"-type S Video cable is a ripoff.
S Video will give you better quality over composite any day, even with a cheap cable. -
Maybe zoobie doesn't mean IEEE-1394. There are many other IEEE-xxxx cables. e.g., for parallel printer connections. Here, the cable construction can impact the maximum length of useable cable.Originally Posted by CCEncoderJohn Miller
Test Caps - various composite and s-video cables
By BrainStorm69 in forum Capturing and VCRReplies: 36Last Post: 12th Apr 2012, 14:51 -
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 01:17 -
New Place to Buy Cables
By Bodyslide in forum DVB / IPTVReplies: 1Last Post: 16th Nov 2008, 00:09 -
Component vs composite cables
By PhoneMatt in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2008, 08:36 -
Do you buy premium cables for your entertainment center?
By yoda313 in forum PollsReplies: 16Last Post: 27th Aug 2007, 14:11
