  1. i have just decded a avi file to mpeg using tmpeg, i watched this and everything was fine i then cut it to fit on 2 cd's and after the mpeg files seem to stop and start for a mill second then carry on, whats wrong? have i done something wrong? should i make sure no other apps are running at the same time?
  2. What are you using to play the VCD? PC or DVD/VCD player?
    What software are you using to cut the MPEG file? TMPGEnc? TMPGEnc Merge & Cut tool is a bit buggy. Sometimes you need to run several times to make it work. Make sure your system is not running many HDD intensive tasks while it's cutting and/or merging.
    If you play it on a player, you might have some media/burn speed fine-tuning to do make it play smoothly.
    Hope this helps.
  3. I have noticed that sometimes also that it is the quality of your disks. I have used both crappy and good CD's and it depends on the disk sometimes. This is just what i have noticed when i burn and nothing is runnning but the burning software. (NERO)
    <a href="http://www.nocryders.com" target="_blank"><FONT SIZE="+8">Dont Click Here</a>
    Feb 2001
    Palmdale, CA
    to help with cheap disks try burning at a slower rate, I have found that to cover the most disks and players I burn at 8x. This has created disks that have played well in over 20 different players and using the cheapest disks I can buy.
