Yes, I know "capture" isn't the right word, but it's quicker and less clumsy than saying "transfer the data stream from the camcorder" repeatedly during this post.
So ...
I was capturing widescreen DV video just fine on Sunday, went to pick up where I left off last night, met with nothing but frustration. Premiere 2.0 will control my camcorder just fine (stop, play, whatever) so obviously device control is fine, as well as my cables and FireWire card etc, but the capture preview window is 4:3 when it should be 16:9, and no video plays in it, and nothing captures when I hit record. Premiere 6.5 and WinDV won't capture jack either. I really hate these software glitches. Can someone tell me if they've also had this problem? Is there some little .dll file that's corrupted or whatever? I don't want to have to do a full system restore when it's probably just some little module somewhere that's not working. Any suggestions?
I'd try first capturing without having Premiere control your video device. I myself have had problems with device control with any version of premiere. Either crashing or otherwise.
Try that and see if it helps.... -
I just tried 3 things and apparently one of them worked.
1. Defragged.
2. Started Premiere with the shift key held down (which resets the plugins cache, similar to replacing the preferences file in versions prior to Premiere Pro 1.0).
3. Opened Premiere's capture window, THEN switched on my camcorder, instead of the other way 'round.
Not sure which one of those things worked, but I suddenly got video back in the preview window, so I'm a happy camper once again. -
Capture is a correct term for DV.
An alternate method is to use a low complexity capture program like WinDV. Results are equal unless you're using Premiere's batch capture modes. Another option is Scenalyzer which can separate scenes using optical analysis methods.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Originally Posted by Chaoji3791
Windows communicates with DV devices via Firewire using two protocols.
1. The DV format specification
2. The AV/C Tape Recorder/Player Subunit Specification
The first handles the transmission of the DV data. Microsoft provides a driver call msdv.sys to do this on behalf of applications such as Premiere etc.
The second handles device control (such as play, record etc) and uses a different driver called avc.sys.
Only one application can stake a claim to the msdv.sys driver for a given DV device attached to the computer. Multiple applications can use avc.sys, though.
With Windows XP (32-bit), when you connect a DV device, a new folder gets created that you can see in My Computer - typically it is called "Some Brand DV Camcorder" (obviously, this varies!) When opened, this folder displays whatever is coming from the camcorder and, in doing so, stakes its claim to msdv.sys, so no other application can get the DV data.
This is an easy one to get around - just don't have that folder open.
Unfortunately, there are some rogue apps out there that also seem to grab the device (I think some Roxio and Nero 'features' do this) and create havoc with other, well-behaved apps.John Miller
After Effects Camera controls help
By merciscool in forum EditingReplies: 2Last Post: 21st Dec 2011, 18:13 -
My AG-1980 suddenly won't play tapes. Any suggestions?
By Mini-Me in forum Capturing and VCRReplies: 5Last Post: 26th May 2011, 15:47 -
Some Cable channels suddenly won't come in
By chimneysweep in forum DVB / IPTVReplies: 21Last Post: 6th Feb 2008, 13:26 -
Ffmpegx suddenly won't launch at all
By epa1nter in forum ffmpegX general discussionReplies: 16Last Post: 9th Jul 2007, 21:13 -
Benq DW 1650 suddenly won't burn TY02
By smitbret in forum DVD & Blu-ray WritersReplies: 13Last Post: 14th May 2007, 14:15
