that's what this article is saying:
http://www.reselleradvocate.com/public/ram/rampage/ram60_rampage01.html#story2
overall i tend to agree. i would much rather have a 720p movie that was created from a high quality source and that was encoded properly than a 1080p movie that was created from a crappy source and/or encoded by a chimp.
hell, i've seen 16:9 DVD's that have superior quality to some 720p, again, depending on what kind of film the movie was shot on, how high the quality of the master was and how well it was encoded.
link didn't work
OK got it to work and he says resolution is only one factor in a good image and maybe 4th in importance. Yep, I'd agree. Similar to Megapixels with digital cameras or octane number for gasoline.
Consumers like a linear scale. Something to brag about. -
Sure, a 50" display at 10 ft or more... you probably would not be able to see much difference between a 1280x720 native screen and a 1920x1080 native screen.
However, a 62" display at 10 ft - you definitely can see a big difference. Double the pixels, you know.
There are so many factors that go into getting the best image possible... besides the display's contrast ratio, color accuracy, resolution, etc. The source signal quality is a major factor, and it can vary widely even in the HD arena. Signal processing within the source unit (DVD player, HD cable/satellite tuner, game console, etc.) and image processing done by the TV also affect the picture quality.
To say that there is basically no difference between 1280x720p and 1920x1080i/p is simply not accurate. -
The same would go for "i would much rather have a VCD that was created from a high quality source and that was encoded properly than a DVD that was created from a crappy source and/or encoded by a chimp" It's just evolution.
/Mats -
FYI, there's a ongoing-running discussion on Afterdawn about this. Hope this helps provides more perspective.
720p source or downsize 1080p to 720p ?
By vcddude in forum Video ConversionReplies: 4Last Post: 19th May 2011, 19:40 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35 -
1080p to 720p
By miss in forum Video ConversionReplies: 9Last Post: 7th Jul 2009, 00:38 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23 -
1080p to 720p
By anirban in forum Video ConversionReplies: 6Last Post: 26th Apr 2008, 15:09
