You must set the video bitrate to get the file size you want. You can calculate the bitrate with a bitrate calculator, see our tools section. Then apply the average video bitrate in virtuadub under the divx codec settings.
For Xvid I think you are using 2-pass-encoding and you haven't made the first pass. Change to 1-pass encoding under the xvid codec configuration.
You find the video configuration in virtualdub under video->compression and select divx or xvid and click on configuration/settings.
TextSub filter: how to set a new style?
By Instant Martian in forum SubtitleReplies: 3Last Post: 5th Aug 2011, 12:26 -
TextSub horror!
By YiuKorochko in forum SubtitleReplies: 2Last Post: 1st Aug 2011, 16:38 -
How do I use TEXTSUB.VDF filter in Virtual Dub in WIN 7
By V879 in forum SubtitleReplies: 3Last Post: 10th Jun 2011, 11:16 -
TextSub in Avisynth.
By Sarlula in forum SubtitleReplies: 3Last Post: 18th Dec 2009, 18:24 -
How to create my own default Textsub filter settings?
By GoldNiv in forum SubtitleReplies: 3Last Post: 2nd Nov 2007, 10:44
