hey there! I'm moving in to a new apartment. My old place has regular cable and I use a Pinnacle Studio PCTV Pro and record on my Win2k box with NO problems.
My new place has digital cable and I want to know how to set up my computer to capture from it or if it's even possible. Will I need a cable box? Run the Digital Cable to my S-Video on the PCTV?
I have a firewire card and getting the right software isn't an issue... just need to know what setup to use!
Thanks!!!
loki2099
The digital cable uses a converter box, to convert the digital stuff to standard video (composite or svideo).
You just take that output and use it like any other video input.
As far as I know, there are no digital cable decoder cards here in the us. (I think there are a few in europe).
BTW - I would reccomend satelite, more channels, better UI, less $. (I have both).
dp -
Yes, I use VirtualDub Capture, I have a Digital Cable Box. I use the S-Video from the Box to my capture card, and a capture to AVI and convert to MPEG for VCD and SVCD. I can cap anything that comes across, all channels including HBO, Starz, VH1, VH1C etc.....A great way to do it.
Bud -
Forgot one thing, just set up yur TV Card to channel 3 or 4 just like a VCR, depending on what your Digital Box tells you.
Bud -
I capture digital cable too but capture straight to mpeg2 via s-video. I find that the digital source is so clean and the resolution significantly higher than analog cable that going straight to mpeg2 produces excellent quality.
If at all possible use the S-Video Out and In, it will add to the overall resolution.
Bud -
sweet!
thanks for all the help! I'll make sure I get a cable box and run the s-Video straight to the capture card.
You guys are the greatest!
thanks again
loki2099 -
I find that cable is the superior choice because i have like 6 jacks in my house n my tv's built in tuner works.
Also, i enjoy not having to have a phone line hooked into each reciever.
What Product to buy to view DIGITAL cable TV on my PC?
By trighap in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2011, 16:48 -
Get digital cable into windows media center
By Simoyd in forum Media Center PC / MediaCentersReplies: 12Last Post: 17th Nov 2008, 09:50 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 01:22 -
DVD recorder + digital cable question
By bigkromedogg in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Sep 2007, 10:34 -
They want to sell me DIGITAL cable
By Faustus in forum Off topicReplies: 4Last Post: 11th Jun 2007, 09:03
