So, i got these new media, benQ 8x (daxon08S)
Now i burned the first one of the spindle with IMGBURN and it burned and verified fine. The 2nd and 3rd went all wrong. At 4% of the burn i get a no seek complete error, after 20 retries it fails the burn, showing a sector range were the error happened. Used also nero to no avail, same problem (pic below). Now before wasting more and more media, did anyone have the same problem? Or someone who knows how to solve it?
My last smartbuy batch all went fine with this dvdrw, its almost brand new (1-2 months old)
Log (almost same for both coasters)
Code:I 17:45:11 Source File File System(s): ISO9660, UDF (1.02) I 17:45:11 Destination Device: [1:1:0] Optiarc DVD RW AD-5170A 1.11 (I:) (ATA) I 17:45:11 Destination Media Type: DVD-R (Disc ID: DAXON008S) (Speeds: 2x, 4x, 6x, 8x) I 17:45:11 Destination Media Sectors: 2,298,496 I 17:45:11 Write Mode: DVD I 17:45:11 Write Type: DAO I 17:45:11 Write Speed: 6x I 17:45:11 Link Size: Auto I 17:45:11 Test Mode: No I 17:45:11 BURN-Proof: Enabled I 17:45:11 Filling Buffer... I 17:45:12 Writing LeadIn... I 17:45:57 Writing Image... W 17:46:55 Failed to Write Sectors 107584 - 107615 - No Seek Complete W 17:46:55 Retrying (1 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (2 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (3 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (4 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (5 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (6 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (7 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (8 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (9 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (10 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (11 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (12 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (13 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (14 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (15 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (16 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (17 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (18 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (19 of 20)... W 17:46:55 Retry Failed - Write Error W 17:46:55 Retrying (20 of 20)... W 17:46:55 Retry Failed - Write Error W 17:47:00 Retrying (21)... W 17:47:00 Retry Failed - Write Error E 17:47:01 Failed to Write Sectors 107584 - 107615 - No Seek Complete I 17:47:01 Synchronising Cache... E 17:47:02 Failed to Write Image! E 17:47:02 Operation Failed! - Duration: 00:01:51 I 17:47:02 Average Write Rate: 3,362 KB/s (2.4x) - Maximum Write Rate: 8,638 KB/s (6.2x) I 17:53:23 Close Request Acknowledged I 17:53:23 Closing Down... I 17:53:23 Shutting down SPTI... I 17:53:23 ImgBurn closed!
Cheers
The media list shows mixed results with this MediaID. (See link at left)
Your drive appears to be a product of a relatively new Sony/NEC joint venture with little history.
Check for firmware updates.
Avoid this combination. -
When my liteon died i got a NEC3550A but had problems with it. IT would write perfectly but wouldn't read its writes. Then i changed that to this drive and works perfectly. If i remember correctly i've burned same media before (Benq like the ones i have) with this Optiarc drive too and those went fine. Now i really don't know what to do. I'm a bit afraid of flashing the drive since it can ruin and void my warranty if done bad.
Can it be a software problem? Since the first disk went fine i can't see the problem as the media's fault :/
Cheers -
Have you checked the old media to ensure it was the same media code? There are often bad batches of media, even if the media codes are the same. Try a disc from the bottom of the spindle.
The easiest solution is to just try a different media. If that also fails, then you most likely have a hardware issue.Google is your Friend -
Well, got some updates
Tried another Smartbuy ProdiscF01, Metallic Orange. Worked fine at 6x. No problems all the way through he burn.
Tried rebooting, uninstalling the dvdrw and reinstalling etc, still same problem with the benq media. Giving that error at stopping @ 4% - 6%
Or it is a bad bunch, or my drive isn't compatible. Still if someone has experinec on this error and can help its really appreciated.
Cheers
FLV1 seek problem
By jenova in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2010, 21:00 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Seek Failed
By zeke1312 in forum Video ConversionReplies: 1Last Post: 20th Mar 2008, 06:59 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 14:28 -
"can't seek backward" error
By perfection in forum Authoring (DVD)Replies: 3Last Post: 10th Jun 2007, 05:23
