Does anyone know what the file format is of ATI .VCR. I would like to convert them to MPEG but do not know how to handle them.
Chris
go to ATI's website and search around for the "ativcrx.exe" file. it's both the ATI VCR1 and VCR2 codecs that will allow your system to view these files. it's under something like 'outdated and unsupported software'
Actually converting to mpeg is quite simple. In MMC 7.5 open the ATI Library. Right click on the file and choose export to mpeg. It only takes a minute or so to process the file.
so does this mean in MMC 7.5 the cards can now finally do realtime offline encoding? i still fail to see why they let you capture using the MPEG codecs (their own, or Ligos) but cant let you convet just as fast...
patrickm - The conversion from an ATI VCR2 capture to an Mpeg2 file seems to be just a header adjustment - I think, not really sure. It does not seem to be an encoding process. It only takes a minute or two to export (convert) and ATI VCR2 800meg capture to an Mpeg2 file for example. I am guessing that an ATI VCR2 capture and an Mpeg2 capture under MMC 7.5 both use the Ligos GoMotion codec.
I played arounf with VCR2 captures for a while and did the conversions thinking that the quality of a VCR2 capture may be of better quality. Never really spent enough time on it though.
Convert ATI AIW .vcr format to anything?
By madmartian in forum Video ConversionReplies: 14Last Post: 4th Jan 2012, 07:59 -
from ATI File Player to .mpg (or any format that fits WMM)
By croarta in forum Video ConversionReplies: 2Last Post: 22nd Dec 2010, 11:10 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
How to Connect VCR to ATI 650
By jshapard in forum Capturing and VCRReplies: 0Last Post: 22nd Sep 2007, 12:18 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
