Pretty sure.
Results 31 to 33 of 33
Uncompressed avi (using no compression) the filesize will be around 1.25GB per minute of video and audio with a 704x480 framesize. This will vary I suppose but this figure should be pretty close. If your framesize is smaller than 704x480 then the filesize will also be smaller.Originally Posted by greccogirl
Using Huffyuv compression the same file will be around 400MB per minute of video and audio (give or take a little). Again if the framesize is smaller than 704x480 then the filesize will reflect this and also be smaller.
The filesize of your WMV file is going to be determined by what bitrate you use when encoding the video and the audio, regardless of framesize. Just because the WMV file comes out smaller than the original .mov file is only a reflection of the reduced bitrate that is being used and nothing more. You could also reencode the original using .mov format, or also many other codecs like Divx and Xvid, and get a smaller filesize than both the original and your WMV file by using a lower bitrate.
Hope this helps.
Good luck. -
THANKS all of you for so much help. I ended up getting MOVAVI which is a for pay program and it does do a beautiful job. I will play around with the two programs you guys got me own and hopefully, learn more!
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 11:48 -
Converting or Joining MOV files
By theWallflower in forum Video ConversionReplies: 3Last Post: 8th Apr 2010, 07:00 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 14:50 -
Converting files to Mov For (CyberPix DV-20 CM-ME-DV-20HDRD)
By Zerodude in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 08:48 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 16:46
