Just prior to a recent road trip, I made copies of a few music CDs I own, since the originals would now be hard to replace, and I did not want to risk them on the trip. The copying worked, but the copies had problems. Mainly, false starts and early endings of tracks, as if the copy program did not understand where tracks begin or end . . . or, maybe that music is something other than regular data ? On a previous computer, I did have MusicMatch software (some older version) installed, and had used that to rip music CDs to MP3 format. That is the limit of my ripping experience, when it comes to music CDs. But, in this case, I did not want to deal with MP3s -- just a straight 1 to 1 backup copy. I thought I had done this successfully in the past, but maybe not. Evidently I am using the wrong tool. Can someone point me in the direction of the right tool, one that won't be fazed by copy protection BS ? (We're talking about music I already purchased, so, from that point on, I don't give a damn about whatever the DMCA says. As far as I'm concerned, this backing up is Fair Use.) If the tool happens to be free, so much the better.
Results 1 to 10 of 10
My personal method of ripping CDs is to use EAC (exact audio copy). It is a small freeware program, but takes a bit of setup to get working properly. I will link you to some guides, and give you some tips for 1:1 backups, since it offers an abundance of options, features and ways to rip CDs. You would want to rip to an uncompressed (WAV) image + cue sheet.
Here is a quickstart manual from www.coasterfactory.org: http://users.pandora.be/satcp/eac-qs-en.htm
Here is a set of tutorals from the same site: http://users.pandora.be/satcp/tutorials.htm
A guide from CDFreaks.com forums: http://club.cdfreaks.com/showthread.php?p=639747#post639747
Note: you can ignore the steps about ripping to mp3, you want an uncompressed image + cue sheet.
The EAC Forum: http://www.digital-inn.de/forum14/
Note: As always, read and search before asking questions.
You will need quite a bit of hard drive space for each CD. Albums will likely be 450-650MB per CD. When you finish ripping a CD you will have a .wav (audio) file and a .cue (text) file. To burn these files onto a CD-R, I recommend Burrrn, it is a simple, small stand alone burning application specifically for audio CDs. You can either drag the .cue file onto the window, or open/import the .cue through the programs interface. The .cue file will tell the application where the tracks start/end. Burning just the .wav file would result in one long track for the whole CD, which is why the .cue is necessary.
I hope this helpsSome people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
1.If your Audio CD's are new then it's possible they have copy-protection,if they are more than 6 years old then I would say it's #2.
2.Another possibility is your standalone doesn't like CD-R,try the disc in another player or on your PC.
http://www.dsg.cs.tcd.ie/~haahrm/copying-protected-cds/ -
One thing to keep in mind for future reference re: copying is you never want to rip to a lossy format like MP3, especially if you want to re-burn to CD. A lot of audio gets thrown out by MP3, even on it's best-quality (320 kbps) settings. I'd recommend ripping to WAV and then re-burning as Skith mentioned. Nero CD copy also works well for non-copy-protected CDs. However, if you do run into copy protection the EAC method (along with the use of AnyDVD, which works on CDs too) is more likely to work.
Oh, yes, and using quality media is as important for CD-R burning as it is for DVDs. Try using CDs designed for audio and looking for media that says made in Japan. A lot of the other stuff is rather variable in quality. -
Audio CDRs are the same as regular CDRs, except they have coding on them to allow you to burn them on stand alone CD recorders. The extra cost is a 'license fee' to make copies. There's no difference in quality so don't waste your dime, if you're using a computer to burn.
I also suggest trying EAC as its totally free and after the initial setup which is needed to get the best rip possible with your hardware it will produce 100% exact rips, it may be a bit slower but if you want accuracy rather that speed, give it a try
Also as mentioned, if you intend to burn to another CD, avoid MP3, use a lossless codec. FLAC seems popular, as MP3 is a lossy system, thats how it gets such small filesizes through removing information that it deems not needed
But, run a CD through any good spectrum analyzer software, and then play the same track converted to MP3, even at its highest squality setting and you should see exactly what has been removed
Or just use MediaPlayer with one of the bars visual displays, that should also show you what gets stripped by MP3 conversion
Mainly the high frequencies, but it does make a difference -
Thanks to all for your suggestions, and esp. to Skith for the detailed response + guide links.
Small change, once you've gotten accustomed to ripping DVDs.Originally Posted by Skith
Yes, I'm sure it will.Originally Posted by Skith
Seeker47 -
If you have newer CDs, it might be worth mentioning to turn off AutoRun on your optical drivies. You can avoid some nasties that way, rember the sony rootkit fiasco?
The easiest way is probably microsoft's TweakUI powertoy link
There really is no need to use a lossless compression codec like FLAC unless you intend to keep a copy on the computer or an archive, if you just want a 1:1 copy it would be an added and unecessary step.
Glad I could be of some help, Good luck!Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
Need a free program to burn Music CDs and make all tracks the volume level
By Starry in forum AudioReplies: 5Last Post: 19th Mar 2011, 17:26 -
How to rip the video from (S)VCD CDs or BIN/CUE images
By Baldrick in forum User guidesReplies: 45Last Post: 4th Aug 2010, 06:56 -
How to rip and burn (What to use for both) Karaoke Cds???? Please help. tha
By slayer_of_all in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2010, 20:30 -
QUERY: editing CloneCD images & best for game data & music CDs
By andwan0 in forum Newbie / General discussionsReplies: 6Last Post: 18th May 2009, 21:12 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 19:15
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
