My problem is that when I convert my mp3 audio to ac3 for a dvd there is no volume. I have tried to follow other advice on how to increase volumes with besweet but to be honest, im a noob when it comes to stuff other than the straight forward stuff.
Im not sure if there is no sound or that it is really quiet, at max vol on my speakers there is only hiss. The track is fine before, in mp3. is there a reason why besweet would lower the volume when it converts to ac3? is there any other way to increase the volume of an ac3 file as I have tried increasing the volume before converting using virtualdub which resulted in the same quiet ac3 after I converted the WAV. any help would be great
Results 1 to 9 of 9
I just use media player to play the ac3. I have the 1.11 ac3 filter. I have checked another movie that has ac3 and it plays fine.
If besweet can do the fps conversion correctly ... then you need to check the bitrate used for the conversion ... it's too low .
Click the "ac3 & ogg" button , then in this area over to the left , ramp up the bitrate ... the default is set at 384 .
Also be aware , that even though both the video , and audio will now have matching fps rates , they will not have matching time length's ... which will cause problems .
Why , because the audio come's from another source . -
You could also encode the movie at PAL resolution (720 x 576) at 23.976 fps, then use DGPulldown with 23.976 -> 25 fps. This will give you PAL compliant playback without changing the length of the movie at all. You can then use your ffmpeggui encoded AC3 files. You also avoid the usual quality pitfalls of software format conversion (jerky zooms and pans, double frames and bad blends etc).
Read my blog here.
I tried converting to 25 fps wav file but I just ended up with a file that had no sound excpet for some clicking.grrr
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
Movie Audio to MP3 results in AVI File
By valier_l in forum ffmpegX general discussionReplies: 1Last Post: 23rd Mar 2012, 12:27 -
BeSweet for 4.0/quad AC3?
By RogerTango in forum Video ConversionReplies: 1Last Post: 17th Nov 2011, 03:16 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 18:37 -
MP3 to AC3 - Bad Sound Quality
By urdivine in forum AudioReplies: 22Last Post: 17th May 2007, 03:16
