Hello!
I got a MKV file that i have extracted with MKVextract
(i have to convert the AAC sound)
but video is to short, it is like it have been timestretched, or something??
so everything goes out of sync![]()
What kind of video? AVC/H264/X264? it can be VFR(variable frame rate) and you will get sync problems then, see https://forum.videohelp.com/viewtopic.php?t=312647&highlight=vfr
Identify the video in a MKV with mediainfo or gspot. Or maybe mkvextract gui shows the video codec. -
mediainfo:
General #0
Format : Matroska
File size : 233 MiB
PlayTime : 24mn 29s
Bit rate : 1328 Kbps
Writing application : mkvmerge v0.8.9 built on May 6 2004 19:48:43
Writing library : libebml v0.7.0 + libmatroska v0.7.0
Video #0
Codec : DivX 5
Codec/Family : MPEG-4
PlayTime : 24mn 28s
Width : 704 pixels
Height : 384 pixels
Aspect ratio : 16/9
Frame rate : 29.970 fps
Resolution : 24 bits
Title : [a4e]Paranoia Agent - 01
Language : Japanese
I looked at the thread, and it is the same problem as he got..
but when i'm try to load the mkv file in vdub and do as he díd, it says that it don't support the subformat. -
Oki.. i did find the solution!
I made a new mkv file with mkvtoolnix, without subs and sound...
then: https://forum.videohelp.com/viewtopic.php?t=312647&highlight=vfr
It was VFR!
THANX ALOT FOR THE HELP!
Extract SRT From MKV
By Valentin in forum MacReplies: 4Last Post: 12th Sep 2014, 20:14 -
mkv to mp4 transcode results in fast video
By HSV Guy in forum Video ConversionReplies: 7Last Post: 22nd Mar 2012, 06:14 -
MKV Extract and Merge
By b1tbull in forum DVD RippingReplies: 2Last Post: 24th Aug 2010, 04:50 -
How to extract audio from a MKV?
By takearushfan in forum AudioReplies: 3Last Post: 23rd Jul 2010, 23:51 -
cant extract h.264 video from mkv
By lucas107 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jun 2008, 20:35
