hi
i have vob file on 3 different dvds i want to combine and make them into one DVD,I have tried TMPGEnc DVD author, i get an audio error, it doesnt support dolby sound. Any advice?
thanks
Results 1 to 9 of 9
Tmpgenc dvd author supports dolby sound, stereo/mono and 5.1. Must be something else.
What is the error msg?
Are you importing the vob? or are you using the add dvd video option in tmpgenc dvd author? -
You shouldn't add VOB files (only MPEGs are imported in file mode), import DVD source either by browsing for VIDEO_TS folder or by simply dragging VIDEO_TS.IFO to SET SOURCE window, each track (title) will be imported separately with one of selected audio tracks.
If you just have the vob files you can demux the video and audio from the vob files and then import them in tmpgenc dvd author. Demux vobs with vobedit,rejig. If the audio still doesn't work try run ac3fix gui on the ac3 files.
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 21:00 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
