I have a problem with VCDs. I download episodes of DBZ off the net. Then I put the AVI files onto Nero which automatically converts it to VCD. But when I watch it on my DVD player the picture freezes a bit every 5 seconds. Everything else is ok but could you help me understand and fix the problem.
First of all you should not use Nero to do your converting, that may or may not be the problem, experence tells me Nero will not convert very good. Look to the left under CONVERT and find the best way to encode then Burn with Nero.
Bud
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 10:31 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 02:12 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 18:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36
