whats the best free partition software?
Gdisk - enhanced Fdisk - many more features, plus it can create partitions larger than 512gb - Fdisk can't.
Ranish Partition Manager - can create and resize partitions.
both available here >
http://www.4dos.info/dhardw.htm -
Knoppix is an entire Linux distribution that runs from a CD. No install to hard drive necessary.
It contains QTpartED, an excellent freeware partition manager.
When I bought a Maxtor hard drive a few weeks ago, the MaxBlast software included with it couldn't find the drive onmy PC! So I rebooted with the Knoppix CD instead of the MaxBlast CD, and QTpartED found the drive and partitioned/formatted it fine and dandy. -
Hey Robert...
I been using Knoppix for years to salvage data off of unbootable Windows systems, and I really love that program! I am currently running vs5 (the latest, I think it is 5). Will it format in NTFS, or only edit partitions?
Can you give me the path/basic instruction to QTpartED and on how to partition with Knoppix? I never knew that could be done! Thanx... -
Originally Posted by steve42069
It supports all of the major filesystem types, including ntfs. It can also do non-distructive partition resizing.
http://gparted.sourceforge.net/index.php
LiveCD download link:
http://sourceforge.net/project/showfiles.php?group_id=115843&package_id=173828
Looking for free software to partition and backup netbook partition
By jimdagys in forum ComputerReplies: 4Last Post: 30th Nov 2011, 21:20 -
Question about scanning OS partition using antivirus/antimalware software
By PartingShot in forum ComputerReplies: 8Last Post: 31st May 2011, 16:07 -
Splitting freeware software
By Zeev_Zwaard in forum EditingReplies: 3Last Post: 23rd Feb 2010, 15:01 -
partition management software
By dream_of_luck1 in forum ComputerReplies: 5Last Post: 5th Aug 2009, 07:50 -
Need CD Burning Software/Freeware
By Scooter_NJ in forum AudioReplies: 3Last Post: 5th Nov 2007, 22:52
