Hi all
I would like to burn the live cricket match into DVD instantaneously.
Can you guys throw some info on this.
Regards
janny
You don't rip live TV unless you are cracking cable or satellite broadcasts. Semantics aside, the best option by far is a standalone DVD Recorder. If it doesn't have to be instant, get one with a HDD and just put highlights packages on the DVD.
If you want to do it with your PC then a few of the capture cards claim to be able to do it. However unless you are happy putting only 60 - 80 minutes to a disc, quality will start to suffer.Read my blog here.
Hi guns1inger
Many thanks for ur reply. But i would like to know that, can i use a DVD recorder to burn a 7hrs DVD during any live telecast simultaneously.
Regards
Janny -
Some will, although the quality will be very low. 7 hours on a DVD5 is VCD quality, which is sub-VHS. Some recorders will record at that level. If you can get a DL recorder the quality will be a little better, although still not great. 2 hours on a DVD5 and 4 on a DVD9 (DL) is about the point where quality starts to degrade - and it goes down quickly.
Read my blog here.
Live Video Mixing with Flash Media Live Encoder
By fuggles7 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2012, 14:08 -
Live video to DVD
By HolliB in forum Newbie / General discussionsReplies: 6Last Post: 7th Jun 2009, 19:56 -
Adding live video track to pre-prepared DVD, then finalizing
By ruach in forum Newbie / General discussionsReplies: 5Last Post: 1st May 2008, 15:31 -
Can you record live while also backing up the video to a dvd recorder?
By Todd3353 in forum MediaReplies: 1Last Post: 27th Aug 2007, 00:33 -
Trying to rip audio from Springsteen Live in Dublin DVD....
By robertazimmerman in forum Newbie / General discussionsReplies: 6Last Post: 13th Aug 2007, 23:41
