Just made a copy of my Cabinet of Dr Caligari DVD.
The film is relatively short (3.64 GB) and so didn't need any compression to fit onto a normal DVD-RW
However when I ran DVD2OneX2 (v 2.1.0) it still went through what appeared to be a compression routine before the burn routine, and the final files are showing as very slightly different sizes from the ones which MTR had originally produced (1024 MB instead of 1022.8, 437.4MB instead of 440.7 etc)
Is it likely that DVD2One was indeed processing the files, and if so, is there a way to tell it to just burn straight from the original files? ( I don't have Toast on this machine... )
Possibly DVD2oneX removed some language in audio or subtitles, making it slightly smaller. Open the 'drawers' for included streams and make sure they're all checked.
Failing that, try DVD Imager to make a UDF disc image from the ripped DVD folders, and burn that image file with Disk Utility. -
Originally Posted by gordon k2
For example, this weekend I made a backup of "Dead Mans Chest" to a Dual Layer disc, with no compression. It took 10 - 15 minutes processing the image file before it started the burn process.
There will be times where, even though, you chose not to compress, the end result can still be smaller.
Here's why:
In your preferences, you can set DTOX to keep certain (or all) Audio files (Dolby 5.1, Dolby 2.0, DTS, Directors Commentary, etc). The same applies to Subtitles (English only or others) depending on what you want.
Myself, I keep Dolby 5.1 and DTS (if available) and English subtitles.
If you drop DTS, especially, you notice a Big difference in the Output file size.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
Compressing Audio
By Bacender in forum Newbie / General discussionsReplies: 4Last Post: 15th Jan 2009, 01:46 -
Compressing AVI Files to Burn to DVD?
By ryevick in forum Authoring (DVD)Replies: 17Last Post: 27th Nov 2007, 21:59 -
compressing a video
By Shotobits in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2007, 11:18 -
Compressing DV video
By Duncan1382 in forum Newbie / General discussionsReplies: 14Last Post: 14th Jul 2007, 16:21
