Results 1 to 11 of 11
    Dec 2003
    Cincinnati
    I am trying to back up my son's copy of The Batman and Superman movie.
    DVD Size: 3.28GB
    Mac: Mac Mini: 1.5GHz Intel, 756MB ram
    Ripping: Mac The Ripper 2.6.6
    Burning: Toast 7.1.2
    When the DVDs come out they are choppy and missing sound/video. Since the DVD is small enough, there is no compression.
    How can I tell if it is the Ripping or the Burning that is causing the problems?
    Anyone have any suggestions?
    Play the VIDEO_S folder that was ripped to your HD using DVD Player. Does it play well? If so, the ripping is fine.
    Pick up a copy of Burnz to try the burning elsewhere. Burnz will burn whatever folder you drop onto it as a disc. So drop what would be the top-level folder (inside of which the VIDEO_TS folder resides) onto Burnz and then report back the results.
    Jan 2006
    What media are you using?
    I would donate and get the newest beta version of MTR. Then I would invest in DVD2oneX for the newer DVDs.
    Dec 2003
    Cincinnati
    Does Burnz offer compression? Because Toast does once I get to bigger DVDs. I just wanted to start out with smaller ones and make sure it was all working before getting to anything larger.
    Burnz (http://www.thinkertons.com/) does not have any video processing capabilities; it just burns...and burns well. Set the format for HFS+ and it encompasses all other file systems (including UDF for DVD).
    I've found Toast's Popcorn component (compression) for result in rather poor quality. I prefer to split movies that are too large for DVD5 rather than attempt compression. (Of course, if I'm transcoding to my iPod, there's plenty of compression!)
    Dec 2006
    Hi - I also had some choppiness on the Godfather, but that might have been a poor disk. On the other hand, I tried a pristine copy of Pirates of the Carribean 2 last night and had no trouble copying the enitre disc to ISO using Ripit4me and DVD Decrypter, but the copy was fairly choppy. I did not use DVD shrink, but just copied to DVD.
    Any clues? Do you think it will work better if I copy to VOBs?
    thanks,
    term
    Jun 2001
    Silver Spring, MD USA
    Media media media.
    Just get Verbatim discs and be done with it.
    Dec 2006
    Really? Do you all think this is just a media problem? I have been using Memorex double layer and have been pretty happy, but maybe I will switch,
    thnx,
    term
  9. you really need a newer version of MTR as some of the newer movies are impossible to copy with the version that you're using...
    Dec 2006
    just thought I would share this experience, since I think it verifies the comments about using the best media. I copied several movies (Batman Returns, Last Starfighter, others) to Memorex Dual LayerDisks. Almost all began to skip and hang - consistently about 30 min into the video - in my DVD players. On the other hand, they were perfect when played back on my computer. So I ripped MY DEFECTIVE BURNED COPY through DVD Shrink and burned to a 4.7 Imation DVD and got playable videos. True the visual quality was not as good as the original or dual layer, but at least a full movie without skips.
    I wonder if anyone would recommend a double layer blank of quality? Does the Verbatim consistently work well?
    thanks,
    term
    DVD Shrink is awesome. The user interface is pretty darn nice for a Windows app. Wish it would run in OSX. I'll have to try it in Parallels and report back.
