Just wondered if anybody has problems with Hi-res paper. I have an Epson R200 and R300 and if i print discs of plain paper they both print fine. When i change to hi-res paper (for cd covers) i have problems. It first started with 120gram paper, when i try print it just slips the paper straight through, on both printers. So i switched and got 180gram paper, and that wont feed into the printer at all. I know know its the printers as i gave about 10 sheets of each to a friend with an r220 and it fed both and all 20 printed fine.
Anybody got any advice?.
Do i need knew printers?.
Since the problem occurs on both of your printers, I suspect the problem lies between your keyboard and your chair.
I stopped buying epson printers after my epson 950 went wrong I had 5 in less than a year
and all developed faults(pretty good for a 350 quid printer)i would recomend canons ip4000 works flawlessly and prints cds better than the epson and you can get ink cartriges for 79p from
www.ukdvdr.co.uk
I agree that the Canon printer prints better than the Epson. The colors are brighter on the Canon. But before we start telling everyone how many bad Epson printers we have owned, I suggest the OP start here http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=D...odoid=37368464
You will find the answer.
Win7 drivers for the Epson R200?
By MrSpeed in forum MediaReplies: 0Last Post: 27th Apr 2010, 04:50 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 08:19 -
Epson R200 printer and DVD art
By dymx in forum ComputerReplies: 4Last Post: 8th Jul 2008, 11:57 -
More dvd printing probs with r200
By parman in forum MediaReplies: 4Last Post: 28th Dec 2007, 16:14 -
R200 timing bad--grinding
By juststarting in forum Newbie / General discussionsReplies: 0Last Post: 31st Oct 2007, 04:22
