Hello all,
this is my first post to the forums. Hopefully someone here will be able to shed some light on this for me. this is the situation.
I have a number of vhs tapes, most of which are home recordings. They all contain an undesirable amount of hiss. I recorded the vhs tapes to dvd-r using a panasonic stand alone dvd recorder. I then transferred the dvdr files to my harddrive, so that I could make multiple copies of the dvd-r. I have a sony internal dvd-r recorder, and use nero for burning. What i wanted to do was run some sort of filter on the audio file of the dvd-r. I have sound forge and a few other audio progs, but none of them can open any of the vob files on my disc/hard drive. Is their any way to edit these files? Would I be better off just buying some sort of EQ hardware and have it set up between my vcr and dvd recorder, or is it possible to edit the audio portion of a dvd-r file copied to a harddrive. Any help on this would be greatly appreciated.
Hi! and welcome to our forum!
You can demux / split the audio from the dvd using pgcdemux.
Edit it with sound forge, export to pcm wav or ac3.
Remux / add back to the new audio to the dvd with muxman and you can keep the same menu structure.
See https://www.videohelp.com/guides.php?guideid=937#937 -
There's a lot of methods you could use. I use VOB2MPG to convert the DVD to a single MPEG-2 file. Then I demux or separate the audio from the video. It would depend on the audio format, but you then put it into a audio editor and apply filtering as needed. I use the freeware Audacity. It accepts WAV audio, MP3, Ogg and AIFF. After filtering, I output as WAV, then convert the audio to AC3 with ffmpeggui. I add the MPEG-2 video and the new AC3 audio to TMPGEnc DVD Author and make menus, etc., and author to the DVD format, then burn to DVD.
And welcome to our forums.
editing dvd/bluray audio files, dts-hd and ac3
By krohm in forum EditingReplies: 7Last Post: 9th May 2010, 08:31 -
Advice Req: Filtering Audio Files For A Clearer Sound
By Teac23 in forum AudioReplies: 2Last Post: 27th Nov 2008, 09:43 -
Audio Filtering Program
By dawson54 in forum AudioReplies: 6Last Post: 13th May 2008, 08:10 -
Audio issues with DVD camcorder files after editing
By stantheman1976 in forum EditingReplies: 2Last Post: 15th Oct 2007, 16:53 -
Existing dvd files > Format for filtering?
By grannyGeek in forum RestorationReplies: 20Last Post: 2nd Aug 2007, 00:19
