    Dec 2006
    Hawaii
    ever wanted to capture something that's being played but cannot be saved?
    check this out... all you need is 5 minutes...
    (easy video step by step tutorial)
    http://www.metacafe.com/watch/334681/easily_capture_any_audio_that_your_computer_can_play/
  2. Audacity is easier.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I use CDWave.
    However I also created a 7 minute .wav file called "silence"
    that I insert into SoundRecorder first....pull the drawbar back to the beginning...then
    press record.....when I need to use SoundRecorder.
