Hi again,
I've been experimenting with dialogue normalization and Dolby compression standards. My question is, how are you supposed to determine how long it'll be before an encoder boosts low sounds and lessens louder sounds? I've found that Film Standard seems to work well, but I'd like to know when a sound is either going to boom or be brought down. I'm wording this poorly, so I hope someone gets my point.
Thanks,
Justin
Completely depends on the software. Some apps will scan all the way through the audio file before they do any dynamic range compression. Others will scan a few samples ahead and compensate for any volume level changes.
Read Q #3 at this URL to see how one app does it.
http://normalize.nongnu.org/README.html
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 16:26 -
AC3 Dialogue Normalization so it doesn't change volume of edited original
By c627627 in forum AudioReplies: 13Last Post: 8th Jun 2011, 23:20 -
Question about disappearing program in the "Open with" dialogue
By jimdagys in forum ComputerReplies: 2Last Post: 4th Dec 2009, 04:35 -
mkv video audio normalization / post-processing audio normalization
By o6uoq in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2009, 01:17 -
Normalization help.
By mattstan in forum AudioReplies: 2Last Post: 19th Feb 2009, 14:59
