    Oct 2006
    Greece
    I found out that DVD Lab pro messes up with the subtitles. I have an .srt subtitle file which is in great sync with the .avi file. Then I encoded avi to mpv with CCE, and import subtitles in DVD lab pro. I author and when I play the movie on DVD player, all subtitles appear much earlier than when playin the avi+srt... Is it a dvd lab pro bug or what?
    Apr 2004
    Miskatonic U
    Have you upgraded to the latest DLP ?
    How did you encode you video ? Did you change framerates ?
    I have never had a problem with DLP and .srt subs.
    Read my blog here.
    Oct 2006
    Greece
    actually its not a disastrous problem. All subtitles are displayed 0.5 to 1 sec. earlier. i think its not a framerate issue.
    avi is 23.976fps.... i encode with CCE without changin framerate. I use dgpulldown 23.976-->25.
    My DLP is version 2.22...
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    Nick, check one of your old posts, seems to be the same problem?
    https://forum.videohelp.com/viewtopic.php?t=311320&highlight=
    He's a liar and a murderer, and I say that with all due respect.
    Oct 2006
    Greece
    im sure! this had to do with framerate. i changed from 23.976 to 25 and kept same subtitle. and i was expecting to work? haha
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You can try using subtitle workshop to adjust the subs. You can shift the whole lot by a set time amount.
    Read my blog here.
    Oct 2006
    Greece
    yes thats what i did. thank you people!
