The video was captured off of Sattelite at a 12,000 bitrate. However when I burn it to DVD with Nerovision, the video seems to vibrate every 15 seconds or so. Any ideas why this is? I read somewhere that the bitrate is too high for standalone dvd players. Is this true? If so, what is the absolute best settings when capping mpeg2 in terms of bitrate or aspect ratio etc. in order to get DVD quality video when burned to DVD.
Thanks!
Results 1 to 9 of 9
Max 9.8mbits, https://www.videohelp.com/dvd#tech but use a bit lower to be sure.
But I think that nerovision will reenocode the video if it's not dvd compliant, how long did it take to make the dvd with nerovision? -
i have the same issue when i try to add .wmv files.
basically a solution to this is to use their encoder to make it an mpeg.
i do that and i had yet to face the problem of that again.Elite Bulletin Board v1.0
http://elite-board.us -
OK I will have to try the 9.7 mbits if that is what is recommended??Originally Posted by Baldrick
The only thing is I believe Nero did reencode the video because it took about 20 mins transcoding before burning. Does this not mean that the vibrating video issue should be solved regardless of the bitrate I capture at as long as Nero transcoded it??
Thanks again! -
Hi there. The thing is, my file was already an mpeg2 file. And before burning in nerovision it seemed to transcode before burning. Any other suggestions?Originally Posted by edlomon
apply the same ideaOriginally Posted by Heineken
i also use another program i have to make the video into a avi then go back to make it an mpg
nero is real picky on this for some reasons and it can get time-consuming esp when you have to use 3 different softwares just to make this one dvd.
if you can get your hands on something that make that file into an avi you should be able to solve it that way.Elite Bulletin Board v1.0
Is it a DVB-S transport stream or a capture with a capture card?Originally Posted by Heineken
The reason I ask is that all DVB-T recordings get detected as 15,000kbps when they are actually alot lower normally 3000 to 6000kbps.
By correcting the file with the right software you have no need to re-encode.
I'd be very surprised if Satellite broadcasts at 12,000kbps or you can record in mpeg2 at this bitrate unless it is HDTV of course but then the video resolution would be wrong for DVD.
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
avi to mpeg2 burning problem
By deadwreck09 in forum MacReplies: 4Last Post: 19th Nov 2009, 14:17 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Edited MPEG2 Files Retain Distorted Vertical Framing Upon DVD Burning
By cyberboy in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 20:13 -
Burning mpeg2 to DVD-9 with nero 6
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 04:11
