    Dec 2006
    Brazil
    Hi there!
    I try to extract subs from DVD's, but ffmpeg does not create any .srt file. What am I missing here? I already tried 5 dvd's, select the desired subs, the format (.srt), but no .srt file is created...
    When I try to create just the .srt file, it asks me to select encode video or audio...
    Any ideas?
    I'm on a macbook pro.
    May 2006
    Belgium,Brussels
    You must choose "Extract" under the subtitles options, not "Encode". If you've already understand that, i don't know.
    Question: did you first extract the VIDEO_TS from the DVD's ?
    iBook G4 1Ghz
    Dec 2006
    Brazil
    Yes, I did got the Video_TS decrypted and copied to my HD.
    I thought that encoding it would also extract the subs... I'm trying "Extract" now.
    But one thing is not clear to me: ffmpeg does not do OCR, right? So how does it gets SRT files?
    Also, a bit off-topic: if subtitles on DVD's are actually images, how come that you can change subs fonts on programs like mplayer?
    Cheers, and thanks for answering!
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    The subtitle extraction in ffmpegX gets .pgm image files from the subtitle stream, then performs OCR on those, then writes the results to .txt files, then joins those with time code in a .srt file and cleans up the temp files.
    Dec 2006
    Brazil
    I managed now to extract the subs from some DVD's, but others, with no reason for that, don't show the subs after extraction. They do appear while watching the stream or on the preview, and VLC and mplayer acknowledge them, but nothing is shown... What may I been doing wrong?
    Cheers,
    Francis
    Dec 2006
    Germany
    is there any application for mac that converts graphical .sub files into .srt?
    sub2srt didn't work on the files i need to convert, the app just froze and i needed to force quit...
    There are 3 kinds of people: those who can count & those who can't.
