hi
i have vob file on 3 different dvds i want to combine and make them into one DVD, when copied them on my hard drive and tired to burn them with nero all the vob file were replaced with one and other, can someone tell me a simple way.
thanks
Results 1 to 9 of 9
For quick joining keeping original menus of all source DVDs use DVDRemakePro.
DVD Shrink in ReAuthor mode can also do this, although you wont get menus.
Read my blog here.
I have tried TMPGEnc DVD author, i get an audio error, it doesnt acceot dolby sound. Any advice?
thanks -
I just saw your other post, which I assume is related to the same project. Are you trying to mix different AC3 formats on the one title ? eg. 2 channel and 5.1 ? If so, you can't do it. You need to get a common audio format happening to put them all on one title.
Read my blog here.
yes its realted to the same project, audio file is dolby digital(AC-3),48000hz Stereo,192kbps its multiplexed vob file.im trying to make one DVD from 3 wedding DVDs.
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 12:28 -
Ulead DVD MovieFactory 6 prob w/using 3.7GB mpg to make DVD
By GSP_87 in forum Authoring (DVD)Replies: 4Last Post: 6th Nov 2009, 04:05 -
How to make such DVD?
By Remyisme in forum Newbie / General discussionsReplies: 9Last Post: 27th Jul 2009, 19:57 -
Best software (pref freeware) to make a music DVD that will play in a DVD
By Trollheart in forum AudioReplies: 10Last Post: 16th Jul 2009, 15:12 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10
