I am looking for an external HDTV tuner that I can plug an antenna into and then plug the tuner into a TV. The TV is HD ready.
antenna->hdtv tuner->tv
thanks
Results 1 to 11 of 11
A specitic listing of current tuners is here. Old models should be checked carefully on Google for review of problems and solutions. Many early models had serious issues.
http://www.avsforum.com/avs-vb/showthread.php?t=179095
General HDTV Info here
http://www.avsforum.com/avs-vb/forumdisplay.php?f=25 -
my vote goes for the Samsung HD Tuner DTB-H260F. still waiting for JR.com to ship it
To MJA:
I went to jr.com and could not find it. Could you give me the exact nomenclature to find it.
I do thank you for your reply. -
I have a Samsung SIR-T451, and it works great. I found it on eBay.
I have the following receivers:I am looking for an external HDTV tuner that I can plug an antenna into and then plug the tuner into a TV. The TV is HD ready.
** Hisense, USDigital USDTV DB-2010
** Pro Brand, Digital Stream HD3150Plus DTV receiver
Both are great units, purchased early in the year - 2006.
(my favorite, of course, is the Hisense)
I like the Pro Brand, for its "digital" (numerical) signal strenth readout,
unlike the Hisense, who is analog readout only.
But, I love the Hisense, for its OUTPUT quality (seems a tadd bit better
than the Pro Brand) and also, because it seems to keep the Aspect Ratio
*even* over the Compoite and S-Video leads when plugged into a capture card,
which gives it the advantage being captured this way, an HD source who is
being broadcasted in Widescreen Anamorphic presentation, and retaining
this format for conversion/encoding to MPEG in this format in same, and
without resolution loss. A deffinate plus, if you can find a unit like
this -- you never know when you might want to run the signal over an
composite or s-video lead.
Anyways. I mainly use/run the Hisense's component leads to my dvd recorder
in 480i mode, which also keep the Widescreen Anamorphic presentation in
tact as well.
My setup:
Antenna -> Hisense[component] -> Polaroid dvd recorder[component] -> MPEG
Where: Component is separate R/G/B leads.
-vhelp 4160 -
I checked their website .out of stock for now,they even removed it from their site no idea why,but I can tell it's selling like hot cakeOriginally Posted by mysts
Check onecall.com ($178 free shipping) its $10 more than JR.com but they have a very good customer service I bought my camera last year from them
http://www.onecall.com/ProductDetails.aspx?id=34596
if you are looking for HDMI cable
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024002&p_id=...ormat=2&style= -
onecall.com is also out of stock.
I guess http://www.circuitcity.com is one of the few sites to buy from
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 22:39 -
HDTV Tuner
By olyteddy in forum Capturing and VCRReplies: 0Last Post: 25th May 2009, 17:59 -
Pinnacle HDTV tuner
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 29th Nov 2008, 06:36 -
Can you explain to me what a HDTV with QAM tuner is?
By davidsama in forum DVB / IPTVReplies: 1Last Post: 30th Sep 2007, 15:17 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 00:32
