    Feb 2006
    so i tried burning a couple files to dvd in nero but i got a fail error while doing so, i saved my log and attached it could someone tell me maybe why it happened?
    log.txt
    Nov 2002
    All it says the "convert" section raised an exception (i.e crashed).
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    If you are trying to use Nero to "create" a DVD from an avi file (for example), you will need to do a little reading and use a better tool.
    For a "single click" solution, try: ConvertXToDVD
    For better results, you need to learn to convert to dvd compliant mpeg files and how to author a dvd.
    Google is your Friend
  4. Mod Neophyte redwudz's Avatar
    USA
    What is saw was:
    [13:44:23] NeroVision TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    [13:44:23] NeroVision Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    That doesn't mean much, but it appears to be trying to check the conditon of the writer and didn't get back a report. Strangely enough, it says down lower that the burn was sucessful.
    But I would agree to try a different tool.
