Quick question,
I've edited a little video together. Everything was shot in 16:9 mode, captured with the "anamorphic" easy setup in FCP. The project is an anamorphic project and the canvas is in 16:9.
However when i export my video using the quicktime movie option (as i normally do) it exports as a 4:3 image...
How to I get it to export in the proper 16:9 format?
Thanks in advance
:: ehmjay.
If you don't get what you need here try kenstone.net or the Final Cut Pro forum at discussions.apple.com. Those are the best sources I know for Final Cut Pro info.
If you're exporting to a QuickTime movie (and not back to the camera), are you planning to make a DVD? Your DVD authoring program should ask you if its a 16:9 source or not. If for some reason it doesnt, author the DVD anyway ... Settop DVD players have a setting to stretch video to 16:9 proportions.
the problem is is that the exported quicktime file is not showing as a 16:9 file but rather a 4:3 file (pulls the 16:9 video to fill the 4:3 frame).
the only way i can get it to work properly is to export using compressor... which is fine in the end but is kind of a pain when i just want to create a quick preview file.:: ehmjay. -
My brother had a similar problem with Final Cut Express. He encoded and authored a DVD disc image with Toast and then used MyDVDEdit to change the IFO to automatically stretch the playback to 16:9.
The problem my brother has is he is using a true anamorphic lens with his camera. My consumer DV camera has an electronic setting to create 16:9 video and Final Cut Express recognizes that properly. But with my brother's high-end gear the software doesn't understand how the video was shot. We've tried many things but changing the IFO seems to be the one that works. -
Well, if you can dictate frame size when you export from Final Cut (I cant seem to remember the steps right now), a DV video displayed as 16:9 in QuickTime is 853x480; an MPEG2 video file is 720x404.
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
FCP exporting as QT Conversion ...
By macmithos in forum MacReplies: 3Last Post: 26th Sep 2008, 18:48 -
Capture HD video on FCP
By James in HD in forum MacReplies: 8Last Post: 28th Jan 2008, 17:03 -
exporting .m2v source files out of fcp without quality loss
By MacNiles in forum MacReplies: 9Last Post: 17th Aug 2007, 09:39 -
Exporting Video From FCP and iMovie...
By Mokat in forum MacReplies: 3Last Post: 29th Jun 2007, 19:52
