Hey everyone,
Every disk im burning right now, shows up like this:
There is that little circle line there, and the DVD is at least 3g. When I try to play it, it freezes up. Does anybody know if this is a program problem, Burner hardware problem, or the DVD Disk itself? This just started happening when i switched to a new spindle of DVDs, but 1 out of 4 or so would work. [/url]
What media are you using?
What burner do you have?
what programs are you using to make dvd?
Are you backing up a dvd or making it from scratch(homemade)?What We Do In Life, Echoes In Eternity.... -
Hey Denvers,Originally Posted by Denvers Dawgs
My burner is a _NEC DVD+RW ND 1100A
I'm using DVD Shrink. On one of the DVDs i burned, i used RipIt4Me and FixVTS to decrypt it first.
I tried backing up DVD and making it from scratch. Same results.. Thank you for the help. Appreciate it. -
Probably crappy mediaOriginally Posted by tydytao
It's a WinDATA DVD. The spindle i used before was also WinDATA, but the top of it isnt the same.
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 29th Dec 2008, 00:26 -
Subtitles freezing my DVD?!
By beter in forum SubtitleReplies: 3Last Post: 10th Oct 2008, 19:48 -
Freezing DVD-R
By markannab in forum Authoring (DVD)Replies: 7Last Post: 3rd Feb 2008, 04:01 -
burned DVD keeps jumping and freezing?
By ssaamm in forum DVD & Blu-ray WritersReplies: 7Last Post: 24th Oct 2007, 10:46 -
Troubleshoot DVD Freezing
By melcher in forum Authoring (DVD)Replies: 2Last Post: 23rd Oct 2007, 12:36
