I ripped my 1st DVD (using primarily pinoy2201's guide) and encoded it in TMPGEnc using the SVCD NTSC template provided. I then split it using bbMPEG. I used "CQ" for the encoding mode in TMPGEnc but it resulted in a picture that "jumps" whenever there is motion in the scene (objects don't move across the screen smoothly, they jump to position repeatedly). In low-motion scenes, it looks great (pixelation and resolution are not problems). So I then encoded it using the "2Pass VBR" mode to see if this would solve the problem. It took 4 times longer, but the picture still jumps in the same places. So am I not using the best mode or settings (I kept everything else at default in the template)? What is causing this and how can I get rid of it so I have a smooth SVCD (preferably still using TMPGEnc)?
BTW, the movie is T2 if that matters.
the feild order is set wrong. advanced tab of the settings in tmpg... switch the field order to the opposite of what it is.
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
SVCD: Picture is not completely displayed during playback
By czerro in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2007, 13:53
