First, I'm an absolute novice. I have a Toshiba SD-R5372 DVD drive, using Nero Visionexpress 3, ATI TV Wonder Pro.
I'm trying to create a dvd of my son's wedding from a Hi8 cassette. I capture the video successfully to an mpg file, which I can view using WIN Media Player and others. Full color and sound.
I fire up Nero, add the video, create some slide shows from wedding pictures, create a menu, test the compilation and all looks good. I can create a VIDEO_TS folder on my hard drive and the compilation plays on the computer.
I have burned using both DVD-R and DVD+R and both give the same results: both will play back fine (full color and audio) on the computer. Both will playback in full color on a Toshiba SD-5980 DVD player, but no audio with the video. Both play in monochrome only and with no audio on a Toshiba SD-K620 DVD player.
What am I missing?
Thanks.
Some US DVD players can only play AC3 and LPCM audio. You may be burning your DVDs with MP2 audio.
Also make sure you are burning an NTSC DVD, not a PAL DVD.
Both settings are on the Video Options dialog. -
Thanks for the response.
I am recording NTSC, and the audio format is set to "Automatic".
The audio choices are LPCM and Dolby Digital (AC-3) 2.0
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29
