hi
i use sony120 handycam, and want to know what fast captureing device and software to use to make good quality DVDs and VCDs.
thanks
biggest thing is a proper hard drive, any SATA that is 120Gb is size should be ok, then any PCI firewire card to capture. There are many capture programs that you can use that are good.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
To begin with, get used to the fact that transfer will be real-time. A 60 minute tape will take 60 minutes to transfer. If you transfer as DV is will also require approx 13 GB of HDD space per hour.
If the highest possible quality is your goal, you will then need space to encode to. A second drive for this is good.
If you are happy with good - OK quality, you could consider a real-time encoder - hardware assisted if possible.
If you just want good transfer, and aren't going to create complex menus and do a lot of editing, the simplest quality solution is a DVD Recorder with firewire and a HDD.Read my blog here.
What Hardware/Software do I need?
By Frank W in forum Newbie / General discussionsReplies: 7Last Post: 3rd Apr 2012, 18:30 -
Capturing hardware advice
By johnestan in forum Capturing and VCRReplies: 0Last Post: 24th Sep 2011, 20:13 -
Capturing PC Gameplay Videos with Hardware: Possible?
By darkarn in forum Capturing and VCRReplies: 22Last Post: 1st May 2010, 14:33 -
Brand New to Capturing. Need Hardware/Software help!
By kevinhanson in forum Capturing and VCRReplies: 9Last Post: 19th Apr 2008, 20:46 -
best capturing hardware?
By demonwarrior in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 12:00
