There was a sudden power-off the other day due to a storm.
The computer boots up fine but there is no picture on the screen. So, I shut down the computer using the keyboard.
I tried to diagnose the problem myself and found out that when I disconnect the keyboard (PS/2) it boots up normally with normal display on the screen and everything works fine (no keyboard, of course).
Looks like some conflict with the keyboard.
Do you know what could be the problem, please?
Thank you.
try another keyboard
I am just a worthless liar,
I am just an imbecil -
May be so, but that keyboard works fine in other PC.
I was interested in the cause of the problem. I mean: What a keyboard has to do with a black screen? -
Not all keyboards are made the same ... as is the problem with all hardware .
Just like those usb to ps2 convertors for keyboards and mice ... some work , and others are plain crap ... and dont work with all keybaords / mice .
The difference between them is usually , one has proper earth , the other dosent .
Have you got the pc that had the problem running with another keyboard ... ps2 or usb . -
Yes, I replaced the keyboard with another PS/2. Seems to be OK now.Originally Posted by Bjs
I was puzzled because the old keyboard worked for a long time and keeps working in other PC (both XP but very different hardware configuration).
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
Safe way to restart (re-boot) without the screen
By edong in forum ComputerReplies: 10Last Post: 30th Sep 2010, 19:37 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
no boot device available after blue screen
By majax79 in forum ComputerReplies: 13Last Post: 13th Aug 2008, 16:09 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
