what is the best way to do this, i dont want to compress the files so much and lose quality, i want to be left with the best results i can.. how can i put two avi files to a disc (dvd)?
even if need be purchasing a program/application for it
File size in run time??Originally Posted by willhenderson
File size = bitrate * time
Are you trying to author to DVD spec? -
Yea to Dvd,
1 file size 499.mb bitrate = 87kbps running 1:16:52
the other 499mb bitrate 44kbps running 47:27
i figured those would be able to fit to a dvd-r, if not i can always author just 1 file to a single disc of its own, for better quality which i would probably prefer -
Avi2DVD?
I use the method that is totally frowned on here. I use Nero, drag and drop the AVIs. Nero takes forever to re-encode the AVIs (hours) but I have been satisfied with the quality.XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
Post g-spot screenshots of the two films so we can see all the details, however given what you have posted to date, you will only get mediocre quality because that's all you have going in. You also have to realise that watching on a monitor and watching on a TV are two very different experiences. Converting to DVD will expose all the flaws you either have not yet noticed, or are not prepared to admit exist in your source.
Read my blog here.
Several movs/mpgs to DVD / Quality decreases on best files
By soundchaser in forum MacReplies: 4Last Post: 2nd Nov 2010, 11:04 -
WMV files equal to DVD quality
By uniks in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2010, 11:16 -
How to Convert MKV Files into DVD Without No Loss Quality?
By devilcoelhodog in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2009, 18:55 -
A couple simple questions about archival quality conversion
By eyeSpy in forum Video ConversionReplies: 4Last Post: 8th Apr 2009, 10:52 -
High quality DVD and HD files, my recommendations
By ensign ricky in forum User guidesReplies: 0Last Post: 30th May 2007, 16:59
