Hi,
When I run "mplayer -vo dummy -identification <filename.mpg>", I don't think this is displaying audio information at least as compared to some of the examples I've seen. The source is a 8 mm camcorder and my ultimate goal is to burn from my camcorder tapes on to DVD whenever I figure out how to do that. I'm capturing directly from an Hauppauge PVR-350 card using
$ cat /dev/video0 > test.mpg
The captured file plays okay in mplayer and gxine.
Playing test_exp.mpg.
ID_VIDEO_ID=0
ID_AUDIO_ID=0
MPEG-PS file format detected.
VIDEO: MPEG2 480x480 (aspect 2) 29.970 fps 6000.0 kbps (750.0 kbyte/s)
SUB: Could not determine file format
Cannot load subtitles: ./test_exp.txt
ID_FILENAME=test_exp.mpg
ID_DEMUXER=mpegps
ID_VIDEO_FORMAT=0x10000002
ID_VIDEO_BITRATE=6000000
ID_VIDEO_WIDTH=480
ID_VIDEO_HEIGHT=480
ID_VIDEO_FPS=29.970
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=80
ID_AUDIO_BITRATE=0
ID_AUDIO_RATE=0
ID_AUDIO_NCH=0
ID_LENGTH=599.50
I've seen other examples that identified the audio as like mpeg 3 or something like that I think. What is my audio?
I'm running Debian Etch.
Thanks,
Gary
If you've already done the video capture and just want to create the DVD, I would suggest looking at ManDVD
It's very....Nero-ish. The forum and the screenshots are in French, but it does offer the option of installing in English.
(Sorry I don't have the answer to your audio question) -
I found a workaround to my question. I am using idvid from the tovid suite
http://tovid.wikia.com/wiki/Main_Page and it is reliable and well done.
tekkieman: thanks for the pointer to ManDVD, it looks interesting.
Gary
Windows Explorer Doesn't Display Certain AVI & FLV Thumbnails
By ezehelm in forum ComputerReplies: 1Last Post: 4th Nov 2011, 16:20 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Mplayer doesn't detect PCM in ts/m2ts
By qkthr in forum Video ConversionReplies: 2Last Post: 28th Jan 2010, 00:26 -
VLC problem - doesn't display full length, only plays bits...
By MikeMGMVE in forum Software PlayingReplies: 3Last Post: 3rd Sep 2008, 15:38 -
Dummy audio file in silent DVD?
By elkfir in forum Authoring (DVD)Replies: 4Last Post: 3rd Oct 2007, 00:24
