I was going to buy this player replacing my DVP642 because of the HDMI output. My TV is a Sony MFM-HT75W LCD TV: http://www.trustedreviews.com/displays/review/2005/06/23/Sony-MFM-HT75W-17in-Multifunc...ion-Display/p1 I have a few questions before I buy the player. I will buy a HDMI to DVI cable, then I will need a mini jack to RCA for audio. How will I be able to hear the audio from the TV? Theres a pic on that link that shows the DVI VGA and 2 small audio out holes for a mini jack. Im sure if I buy a mini jack to RCA and plug it in the player I wont get audio because its not on the same channel. Example: say I use S-Video I can't use any other audio RCA jack thats not on the same channel as s-video.![]()
I just connected a audio cable from the DVD to the TV. Plays great on my TV speakers. I have a HD Toshiba. Then a coaxial to my Yamaha. if I want to play through my receiver. Should be no complications with any TV.
Ok thanks I will try it out. First I have to buy a Mini Jack to RCA to connect to the dvd player, then a hdmi to dvi. I will buy this after xmas so I will post my results after that.
Philips DVP5960 and USB
By lets in forum DVD & Blu-ray PlayersReplies: 715Last Post: 10th Jun 2012, 10:03 -
.mkv on Philips DVP5960?
By Conrad007 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2009, 11:11 -
philips dvp5960
By tonie in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 14:58 -
Philips DVP5960 or 5982?
By siskiou in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Apr 2008, 21:28 -
Philips DVP5960 Help
By clubfoot in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 05:39
