I'm trying to convert a video from MPEG4 to an .avi container and add subtitles (and reduce the filesize), yet nothing I do ends up doing anything other than running for a second or two, and resulting in a zero byte file. Also I noticed that under some subtitle burn options, in these attempts, refuse to let the position be changed from 80%, which is wayyyyy, to high.
There might be something wrong with the audio (even though it plays fine in over 8 apps), because of the log file output (which occurs in most attempts):
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Audio format 0x6134706d is incompatible with '-oac copy', please try '-oac pcm' instead or use '-fafmttag' to override it.
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
I'm not certain exactly what this means, or how to fix it (and if there is a way to modify the burn position of the subtitles, if the GUI won't let me). Any help will be appreciated.
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
Help with brief video freezes in mpg4 avi
By hibbs in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2010, 19:04 -
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 07:44 -
From Point & Shoot Digital Camera AVI to Xvid High Quality
By kamil in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 10:28 -
mpg4/mpv to avi ....No Video
By trueman in forum Video ConversionReplies: 30Last Post: 24th Jul 2007, 10:40
