  1. Hi everyone I just go t a divx dvd player to play my divx movies, however they are too big to fit onto a cdr. Is there a program out there that will split the movie. I have been looking at avidemux because it compares with vdub for the pc. Any input would be appreciated
  2. D-Vision 3 does the job well.
  3. Originally Posted by ffooky
    Burn it as Data onto a DVD...that works also....or ffmpeg and convert it to a dvd.
  4. hi i just installed DVision 3 and it won't run. It keeps telling me it needs to install a compatible mencoder, but it never installs it. Is it compatible with OS 10? Is there another program I could use? I do not have a dvd burner just a cd burner, thats where my dillemna is. It's in the disc. I have to be able to split to be able to burn the movie. Thanks for the help.
  5. Yep, D-Vision is completely OS X compatible on both PPC and Intel machines.
    I can't remember what happens when first installing D-Vision but does it download mencoder by itself or are you prompted to download and then locate ?
