Hi, I have three MPEG files that I want to convert to MPEG2 and then author a DVD with. But I have a couple problems. First, the aspect ratio of the MPEG files is really weird. It is stretched horizontally, but I don't think it is 16:9. Anyway, I want to get them to 4:3, so how should I do that? Also, what is the best way to convert MPEG1 to MPEG2? Will TMPGenc work fine for this? Thanks!
Load your MPEG file into VirtualDubMod and then use the option called, "Snapshot source frame" to save an image from a frame to a graphic file. You can save as a PNG file then load the image here. Make sure you pick a good clear frame that isn't overly dark nor overly bright.
Also load the MPEG file into GSpot and then take a snapshot of that and load it here.
For more information on how to do this read this link: CLICK HERE
That link will explain how to make a screenshot from GSpot and how to load that into a post along with your image saved out of VirtualDubMod of the actual video.
I or anyone else will need this information in order to give you any proper advice.
- John "FulciLives" Coleman
P.S.
If you need a good freeware image editing program may I suggest PhotoPlus 6"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Aspect ratio problem: Converting 2.35:1 AVI to DVD w/out squishing
By Calidore in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2015, 12:33 -
Fixing aspect ratio?
By hiimbored in forum DVD RippingReplies: 16Last Post: 9th May 2008, 14:40 -
Fixing wrong aspect ratio.
By mattstan in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 15:17 -
fixing aspect ratio
By wayshway in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2008, 11:21 -
Help figuring out aspect ratio? converting DVD to 16:9 media player device
By LedZepFan7183 in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2007, 14:33
