Is it possable to write the subcode that is on a Digital Audio CD-R to make any CD-R into a Digital Audio CD-R. I own an older phillips CD-R stand alone audio recorder but wants only to run digital audio discs, What can i do to avoid hunting there brand discs down, CD-R discs can be found almost anywhere and i need to be able to use this recorder.
Thank you.
No.
It's not in the subcode. I expect it's either in the Burst Cutting Area (although I think this is just for DVD's) or in the PCA/PMA temp areas of the recordable (which are BEFORE the Lead-in/TOC).
Scott -
Hello, Mdniterder!
On a related note, if you still want to go via standalone CD recorder and not via computer CD drives albeit the impossibility of changing a data CD-R to a music CD-R, let me tell you that there are ways to fool some standalone CD recorders into thinking they have a music CD-R while actually having a data CD-R. Obvioulsy, this results in the possibility of recording on data CD-R's and not necessarily on music CD-R's. You can find this information on the Internet. Still, this approach works just on "some" standalone DVD recorders, so your unit might be in luck or might be out of luck.
Carlos "Shale" Lacaye
Disco Mak
discomakberto at megamixers dot co dot uk -
From my understanding its called a flag on the cd that states it is a CD-R/RW Digital audio or music.
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 18:24 -
Getting blank screen (with audio) after converting MKV to Bluray ..
By ahmadka in forum Blu-ray RippingReplies: 6Last Post: 30th Apr 2010, 09:40 -
Digital Audio Out
By joelson in forum AudioReplies: 1Last Post: 20th Sep 2008, 18:52 -
Audio CD to digital
By igorek in forum AudioReplies: 14Last Post: 28th Oct 2007, 23:16 -
Printable Audio Blank CDs?
By mlong30 in forum MediaReplies: 11Last Post: 16th Jul 2007, 15:33
