    Jul 2004
    Italy
    Hi,
    In the last few months I've used the programs in the object to make my DVD (first MPEG enc and then TMPGenc) but I don't know what is happening but the last dvds are of very bad quality and they don't run smoothly as usual. Can you suggest only one program to create a dvd in a fast maneer ( from an avi file)?
    thanks
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If all-in-ones are what you want, then convertxtodvd or its freeware predecessor, divxtodvd should do the trick for you.
    If in doubt, Google it.
