Is there any difference in quality between Autofit and Dvdshrink? Any opinions would help. I don't have time to test out each one. Thanks.
I'll try.
The DVD Shrink option can only be used after your files are converted to MPEG2 or MPEG1 if you use those. It will kick in if your DVD folder is too big to fit on a DVD. The autofit feature is used during the conversion to MPEG of your avi files. Therefore, the autofit feature is better. You only do one conversion with autofit whereas the Shrink wil be two conversions, sort of. Hope you understand this!
Mark -
It would also depend on your final output size. As a rule, it is always better to use an encoder (autofit) to do the job than a transcoder (DVDShrink).
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
I've always used Autofit and have always been pleased with picture quality. I tried it with Shrink and found it to be a little worse so it seems you guys are right. I'll stick with Autofit. Thanks.
Better for quality image: Dvdshrink or Divx encoding?
By perdomot in forum Video ConversionReplies: 1Last Post: 26th Jul 2009, 09:19 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
Output quality and settings of DVDShrink
By src2206 in forum DVD RippingReplies: 21Last Post: 23rd Jan 2008, 07:38 -
No Autofit
By Soapm in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 18th Sep 2007, 04:01 -
DVDShrink No Compression = full quality?
By dreborn in forum DVD RippingReplies: 6Last Post: 12th May 2007, 13:20
