VCD
  1. hi all......im trying to make a avcd of my childs christmas play....i ripped the mini dvd from my handycam with dvdshrink....
    can anyone point me in the right direction?......i have nero startsmart...thanks
  2. Heres a choice of tools for you to try. Sorry I get into specifics but its been years since Ive made a vcd. I think I used "TMPGEnc and virtualdub". Old versions
    Good luck
    Life is like a pothole, you just have to learn to get around it.
  3. Originally Posted by dvdguy4
    Good luck
    thank you...your help is greatly appreciated...i will try those.......
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Why not use DVD and not lose any quality?
    Google is your Friend
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    If you have to go the VCD route, take a look left under CONVERT, DVD to VCD.
    /Mats
  6. Member Cornucopia's Avatar
    rocketboy,
    "AVCD" can be a daunting project, especially if you aren't even familiar with standard VCD. Just so we're on the same page, what are you specifically meaning by that term? (I know what I think of)...
  7. Originally Posted by Cornucopia
    I've made a step-by-step tutorial with images. Just click here.
