    Jul 2004
    I have demuxed MPEG2 files that have working strereo tracks ( I know this beacuse I can playback the audio in Quicktme Pro and hear both tracks).
    If I try to convert the file to divx, MPEG4 or H264 (and I would imagine anything else), the files plays pack fine video and audio, but the audio is MONO. Signal from only one track of the file.
    I have trued converting the file using ffmpegX & VisualHub with the same results. Checked all the advance settings with no success.
    If I select having the file convert to mono, then I get the mono track out of left and right.
    Any ideas?
    Using latest OSX and MacBook Pro
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Is this the kind of stereo that has language 1 on one channel, and laguage 2 on the other channel?
    Jul 2004
    no. actually these are TiVo files that I converted. They look great only having this mono issue...
    Might try exporting the audio to another supported format; perhaps AIFF or AAC.
