Hi,
I still haven't found perfectly suitable software to authorize my DVDs.
It should be able to do following things:
- accept of course video and audio but also .sup format subtitles
- able to do some kind of simple menus
- accept many clips and not just one
I have tried at least:
- old version of DVDLab (doesn't accept .sup subtitles, otherwise great)
- TMPGEnc DVD Author (doesn't accept .sup subtitles)
- Rejig (cannot make menus / multiple clips)
Is there a free/cheap software which can make all the things needed?
Thanks for your answer in advance,
-+EpiMann+-
Results 1 to 10 of 10
Maybe muxman advanced but I don't know how about its menu creating. www.mpucoder.com/Muxman seems to be down now.
You could also use DVDSubEdit to load your .SUP files and export them as .SRT for use in DVD Lab
Read my blog here.
Thanks but no thanksOriginally Posted by guns1inger
I tried it and it makes a LOT of mistakes when converting from SUP to SRT. Too much manual work to be done.
My Gui for dvdauthor (which is now also a GUI for muxman) is able to use muxman for menu creation. Details can be found here:
https://forum.videohelp.com/viewtopic.php?t=310993
Multiple clips (either as SingleVTS or MultiVTS) are no problem.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I just posted a news item
https://forum.videohelp.com/viewtopic.php?p=1620780#1620780
about new DVD authoring software from SONIC that burns to future formats (HD-DVD and BLU-RAY as well as conventional DVD's)
it handles up to 32 subtitles in a timeline that inputs a script or has its own subtitle editor
oops I missed the free cheap line but left my post -
Hmmm. I wouldn't convert the .sup file to .srt, but to .son, rather. That way you preserve the subtitles as pictures, and can load them into DVD Lab Pro.Originally Posted by EpiMann
Which software can convert from .sup to .son? At least DVDSubEdit is not.Originally Posted by machf
And to be honest that GUI for DVDAuthor seemed to be quite hard for me at least
I'm sure it is not 'harder' to use as dvdlab (for simple menus at least)....that GUI for DVDAuthor seemed to be quite hard...GUI for dvdauthor:
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
can't play bd content after authorizing
By volam1 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Oct 2009, 12:38 -
DVD authorizing
By m baqar in forum Authoring (DVD)Replies: 14Last Post: 28th Mar 2008, 03:51 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
