Guys how can i get my mpeg files and burn them so i can watch them on home dvd players.what exactly do i have to do to get this to work?
If your MPEG files are DVD compliant, you need to 'author' them. This will convert them to the DVD format. See 'WHAT IS' DVD to the upper left for the DVD specification to see if they are compliant. Then all you need to do is burn them to a DVD disc. The freeware ImgBurn is good for this.
For authoring, TMPGEnc DVD Author is popular for this, or you can try the freeware GUI for dvdauthor. There are other authoring programs available in 'Tools' to the left. There are also guides for this process in 'AUTHOR', again to the left.
And welcome to our forums.
Are they DVD compliant ?
Open them in g-spot and compare the resolution and framerates with those discussed in What is DVD (top left corner of this page).
If they are, all you need to do is author them. Plenty of tools and guides in the menus to your left <-
If they are not then you need to re-encode them so that they are compliant, then author.
Some DVD players will play mpeg files from a data disc. You can test this by burning the mpeg files as data. This may not work in all players.Read my blog here.
guns1inger, you added some good points anyway. I'll try to type slower.
If you have never used one of these tools, you just need to install one and try it out! You should find them easy to use - drag your MPEGs into the program, preview your DVD menu, make sure it looks ok, and BURN!
If the MPEGs are DVD compliant you should be able to avoid some processing time. I know that in Nero you need to tell it not to re-encode the compliant files.XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
HA! I've noticed that!
XP
600GB
2G
Joining more than 2 mpegs...
By artphotodude in forum ffmpegX general discussionReplies: 2Last Post: 30th Jul 2011, 10:33 -
SEARCHING: DVD Software WITHOUT re-encoding MPEGs
By jouse. in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2010, 05:57 -
Portable APP to save mpegs from a DVD?
By bigMach™ in forum DVD RippingReplies: 2Last Post: 12th Nov 2009, 09:07 -
playing mpegs on a dvd player
By fromunda kid in forum Video ConversionReplies: 8Last Post: 9th Mar 2008, 13:30 -
Extracting MPEGs from defective DVD's
By TPFKAS in forum Video ConversionReplies: 3Last Post: 26th Sep 2007, 03:01
