I created subtitle with subtitle workshop. I want to convert video with subtitle into FLASH video(FLV)
So I want to embed subtitle on video, not separated susbtile file.
How can I do it??
You're kidding, right? Aside from the fact that you dug up a four year-old post, there are easier ways to hardsub a video than to film/capture a player playing the video with the subtitles activated. And, you'll take less of a quality hit, most likely.
For example, if you have an external subtitle file, you can use AVIDemux and load the subtitles with the appropriate subtitle filter, re-encode, and you'll have your hardsubs. Granted, I don't think AVIDemux supports encoding direct to FLV (at least, the original version of FLV), but this is just an example.If cameras add ten pounds, why would people want to eat them?
Video Editing - Embed motion video into Still Frame/Photo?
By staticGenerator in forum EditingReplies: 2Last Post: 4th Apr 2012, 19:54 -
Embed subtitles onto video
By Burnerneil in forum SubtitleReplies: 2Last Post: 20th Aug 2009, 15:30 -
How to embed subtitle and reduce file size to be playable online? [SOLVED]
By mriddler in forum SubtitleReplies: 3Last Post: 5th Apr 2009, 07:38 -
Embed subtitle file into mpeg2?
By bits in forum SubtitleReplies: 7Last Post: 27th Dec 2008, 00:41 -
Anyway to embed this video on my site?
By Mysteriouskk in forum Newbie / General discussionsReplies: 5Last Post: 8th Dec 2007, 17:07
