Hi Crissy
been using the program for quite a while now and no problems except now
it was working fine yesterday but i noticed when i updated WMP to v11 today
it started doing this , i tried to play the splash file but it encounters a problem with WMP
so i guess its something to do with this .
I also installed the framework and SVCD/DVD twice but still no joy and a system restore
The program still converts and works to my knoledge as i burnt a dvd and watching it now
but the error still shouldnt be there and im afraid in case i do alot of work and its messing it up
i hope the info helps you to solve my problem
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error
at QuartzTypeLib.FilgraphManagerClass.RenderFile(Stri ng strFilename)
at x3284ccece41ee22b.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
at x3284ccece41ee22b.x210ff09a2516b1a7.x92b839eef7ea4 c46(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.1.2474.30185
Win32 Version: 2.1.2474.30185
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
DevComponents.DotNetBar
Assembly Version: 5.9.0.0
Win32 Version: 5.9.0.2
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
It seems that upgrading WMP has caused it to not be able to play mpeg1 files... What is the WMP error?
The WMP error says 'Windows Media Player encountered a problem while playing the file .For Assistance, click web help '
i clicked web help and guess what no help
so now im stuck with this problem -
You could try installing mpeg codecs again. Try https://www.videohelp.com/tools?tool=GPL_MPEG-1_2_Decoder after which you will need to reboot.
i installed the package and restarted but no joy ,
i know there is one way to fix it but its not an option i would need to reinstall everything from scratch and not update WMP but i have over 600GB of stuff i need .
i noticed this problem is popping up over the forums now that people are having problems playing mpeg so yes again thanx to microsoft for screwing things up again
thanx for your time and if you ever find a solution please let me know asap
Mark -
ok. try using https://www.videohelp.com/tools?tool=DirectShow_Filter_Manager to increase the merit of the filters you just installed to the maximum... again a reboot may be required.
can you explain how do i boost them i dont want to break pc
is there a guide to how i do what you ask im geting desperate now
i'll try anything well except a format -
Error from sub starting at time = zero with GfD
By AlanHK in forum SubtitleReplies: 0Last Post: 26th May 2011, 12:03 -
Starting Point
By NeptuneDrew in forum Video ConversionReplies: 10Last Post: 19th Jan 2011, 14:40 -
What is the downside of using unspecified framerate?
By mrttmr in forum ffmpegX general discussionReplies: 9Last Post: 11th May 2010, 18:54 -
Ever Had This Error: Unspecified Drawing Error
By boofer in forum Authoring (DVD)Replies: 0Last Post: 22nd Feb 2009, 04:27 -
starting over-codecs
By uglijimus in forum Video ConversionReplies: 5Last Post: 14th Jul 2007, 08:57
